Merc '86 175 for KCLOST bleed hoses
ronmold
do you have a 175 w/vertical reeds? If so could you help me connect my "bleed hoses" correctly?<br /><br />Also have an inconsistant temp at full throttle. <br />I am getting a pressure gauge :cool: .
dnewell
Re: Merc '86 175 for KCLOST bleed hoses
I have a 1986 175 but i don't know about the reeds. I sprayed deep creep in my carbs and know it misses out when I push the throttle forward. It clears up at full throttle. Any idea what causes this? DN
shelbydriver
I have a manual here that shows the diagram. not sure if your year is covered <br />wheaticat@aol.com<br />Tim
ronmold
Hey, KCLOST are you out there?
KCLOST
Yea, I'm here, but I'm not sure I can help you.. Let me take a look at my motor and I'll see if I can help you...<br /><br />Also, take a look at this site and using your SNumber for your engine you can look different parts of the engine and take a look at schematics of it....<br /><br />Here it is...<br /><br /> http://www.dougrussell.com/partscatalog/collections/index.cfm?fuseaction=collectdetails&colid=01 <br /><br />I hope this helps...
Joey O
If you want, I can scan the "bleed line routing" page out of the tech manual & send it to you via e-mail. It will have to be on Tuesday as my home scanner is down & I'll have to use the on at the shop & were closed Mondays.<br /> Also I'll need to know if it's a five or six line system, the only difference will be the five line system does not have a fitting at the #5 cylinder.
ronmold
Thanks guys, mine is a 5 hose which makes me wonder how important they are if cyl 3 doesn't need one. Heres how mine is now:<br />1 reed to jug 4<br />2 reed to jug 5<br />3 reed to jug 6<br />4 reed to jug 1<br />5 reed to jug 2
