Merc 9.8 Compression
bjarnold1
I have a 1967 Mercury 9.8hp that the compression is 120 on cylinder #1 and 110 on #2. Is this low?
bjarnold1
Re: Merc 9.8 Compression
Is there a way to run the motor with the prop shaft missing?
Laddies
Banned
No not with the uni on as fwd gear is c enter in the housing with the propshaft but if you remove the housing the engine can be started to see if it will run or if you hook a small water hose to the water tube it can be run through warmup just don't rev beyond 1500 RPM
