briguy1960
- Joined
- Oct 10, 2007
- 5
Recently acquired merc 9.9 two stroke sn# OG288440 Which I believe makes it a 1995 or so.
When given to me i was told it does not cool. I dropped the lower unit and looked at the impeller--it looks fine ie no missing blades but maybe a bit worn? I was quoted 114 dollars which seem like a lot. Also I can't help but notice that the interconnect between the impeller discharge seems kind of under engineered. ie it just butts up to the rubber thingy at the bottom of the pickup tube---seems a bit goofy to me. The motor has a thermostat which seem fine although I also tried running the motor with the thermostat removed. Very little water comes out of the telltale and the water that does come out seems very hot. When I tried it withe the the thermo in it came out too hot to stick my hand under and at idle the telltale all but disappears.
I removed the telltale from its exit out the engine and tried blowing compressed air through it and only a few bubbles came out of the barrel immersed leg. It really seem like either the impeller is not pumping much or a lot of the water it pumps out it leaking out where the the pickup tube joins the impeller (alot of water seems to be coming out about halfway up the leg) or the cooling passages are plugged up.
Any troubleshooting advice would be appreciated
Brian
Brian
