Re: merc 90 carbs
Thanks for the reply. I am having a hard time finding a clean set of these carbs. I have one that the jet is all buggered up. someone tried to remove it to clean and it broke.
After logging into this forum yesterday and reading a ton of posts I find that my problems might not have been carbs after all but maybe a stator that was going bad. The motor has run fine for 6 years. strong compression in all 6 cyls (125 across all 6). It was running fine and then just stalled from a wide open run. It was hard to start and then would not go over 2000 rpm. We cleaned and checked the fuel system, changed plugs and checked spark on ea cyl.
am I on the right track????
the motor is a 1986 merc 90. The only problem in 6 years of ownership is 1 switch box.......
any thoughts??
