So have been dealing with a problem for awhile and I’m trying to get down to the root cause. Maybe I am missing something so that is why I’m asking here. Every weekend when I go and try and start it won’t. I have narrowed it down to fuel. And water in fuel. To start it I hook a portable tank. It starts. I run it for a bit then I hook up my below floor tank again and it runs fine all weekend. Until it sits for a bit. That’s when I think the water settles to the bottom.
so the obvious is a leak somewhere. But I can’t find it. It looks good! No fuel is leaking out. At one point the bilge flooded and I believe at lot of water got in at that point and I did notice some loose screws on the fuel gauge connection. I think that is where water got in. I sucked out what I could but still some is on there. Maybe this is just the residue of the water and eventually it will be gone? I just added some “water remover” additive. It’s probably ethanol. I’ll see if that works. At this points it’s got to be very little water in the tank. It just seems like my initial start would be drawing water and maybe hitting the spark plugs.
My question is more on the lines on condensation. It seems like the tank vent is open to atmosphere. Is that how it should be? Or should there be some vapour pressure in the tank? Thanks for your comments!
