I am new to the forum and boating for that matter. Having a problem with my 2003 merc 90 4stroke. It idles fine and runs well at low rpm but when I throttle up to get on plane it idles way up to 4000 rpm and more without gaining much speed. It just plows through with the bow ridding high, and some vibrating at around 10 knots barely gaining speed. Eventually it planes out and I can reach top speed around 35 mph and sounds fine. It feels like the power just isn't there in the mid range. I changed all the fluids and filters and plugs. Oil was nasty, the plugs had all similar wear and found real bad chunks of shellacked gas in the fuel filter. Also the bulb and exterior gas line was lined with this shellacked gas so we changed this out for new parts and added an in line filter. Took apart all the crabs and gave a good cleaning to the jets and ports which were not clean but not to severelly dirty either. Ran fresh gas directly to the motor and it's still behaving the same, maybe just a little improved. Anybody got ideas or a direction I should head in.
Thanks
Thanks
