Merc Alpha 1 350 down need advise
cjflanagan
Some folks like to sail, some folks like to fish. Myself I like to go fast. Last august I bought a 1989 Glastron Futura 227 SL. I have used this boat nearly every weekend since I bought it. It has grown to be very fun hobby for my wife, my girls, and myself. <br /><br />Last night was the end of four weeks of degrading performance, which ended up in me barely making it back onto the trailer. Here is a rundown of the degradation that I have experienced:<br /><br />1) About a month ago I put into a lake here in middle Tennessee called Normandy Dam. I was headed out when the engine started to cough and cut out. It didn’t die, it just coughed a few times and then went well. It actually reminded me of my father in law’s old Plymouth Fury. It had a 2-barrel carb and one of two things would happen when you stepped on the gas hard, it would either get up and go like hell, or it would cough. I discounted this event as a learning experience because the temperature was only about 140 and usually it’s about 180. Once it warmed up things seamed to be better.<br /><br />2) About three weeks ago, I began having trouble getting on plain, the engine just seamed to not be all there. Once on plain though the boat ran well again. The water temp was about 180. I was having some trouble with a water leak from somewhere under the engine and the bilge pump was dead so I discounted this to the weight of the water in the bilge which I estimate to have been about 15 gallons of water. When I first got the boat, it had the leak and the mechanic who was inspecting the boat for me said it was coming from one of the winterizing drains which he tightened and the problem stopped. Now it’s doing it again but the bilge pump is working great and keeping the water out.<br /><br />3) Two weeks ago the boat ran great. Checked oil. Looked good.<br /><br />4) Yesterday I put 20 gallons of 87-octane fuel (which I have been using all along) and 8 oz of STA-BIL fuel stabilizer in per the instructions on the bottle. The boat was hard to start but once started ran well. I headed down Tim’s Ford Lake wide open and pulling about 45 mph a drop from the normal 53. A few coughs getting going. Stopped to fish and opened the sundeck (exposing the motor) I was shocked to see oil in the bilge! Checked the dipstick and it was down about a quart and a half but the oil was not foamy or weird looking. I started looking the engine over and found that the area around the top of the dip stick tube was oily. The dipstick was not seated properly in the tube and I believe it was blowing up the tube and out the hole. I seated the dipstick well into the tube and started the engine. It ran fine and came up on plane well but again did give out a cough or two. When I got back to this is when the trouble started. The engine started idling rough and died. It took several tries to get it going again and when it started up it coughed and coughed and coughed. Today I cleaned the bilge and started the boat on the trailer with muffs. The oil problem seamed to be fixed by seating the dip stick in the tube.<br /><br />5) My friends have been telling me they think a tune up would help, and I want to put her up running well, so today I bought Bosche 4 way spark plugs, new wires, cap, and rotor. I have four of the plugs replaced (one whole side) plus the wires. And now she won’t start at all! No I don’t have the wires mixed up, no I didn’t forget to hook something back. It’s more of the same from last night.<br /><br />6) I have run out of daylight and have given up for now. I’m not going to be in a very good mood untill I get this thing fixed.<br /><br />7) So what would cause a slow degradation in power and performance to the point of not starting at all?<br /><br />8) How would you old salts approach this?<br /><br />9) Oh one last thing, my mechanic told me next season I would need a gimble bearing.<br /><br />Thanks in advance,<br /><br />Chris
Trent
Re: Merc Alpha 1 350 down need advise
The slow decrease in power could be water soaked foam (since you said you had a good bit of water). A good carb cleaning might be in order (coughing is normally a lean condition). If its coughing just when trying to get on plane, then the adjustment of the accelator pump may be all you need. As for not starting... You did not say if this is a point and condensor setup or electronic ign. Check for voltage at the + side of the coil with the switch on. How much voltage? You need at least 9.5 volts. When starting you should have full battery voltage 12.5 volts. Check for a pinched wire down in the distributor. This can ground out the ign. system.<br />Be good to your engine and dont run it wide open all the time.
Rhadley
If I were you, I'd do a compression check on all cylinders to see if there is a leak past the piston rings that might cause oil to be forced out the dipstick tube. Maybe it built up enough pressure to force the dipstick out? This is just a guess.
cjflanagan
You did not say if this is a point and condensor setup or electronic ign... How can I make sure? It has a coil I know that for sure....
cjflanagan
I will do a compression test... But don't I have to have the engine running first?
cjflanagan
How do you get the water out of the foam?
johnkc
gas and a match, sorry couldn't resist.<br />the floor has to come off to expose foam to be able to replace it.a lot of work and expense, lets hope your foam isn't water logged .
Fishermark
To do a compression test you do not have to have the engine running. (In fact, you can't do it with the engine running! :eek: ) Simply remove all the spark plugs, disable the distributor, (disconnect the wire), and screw the compression guage into one of the spark plug holes. Turn the engine over several revolutions using the starter motor. Keep an eye on the guage. It shouldn't take more than a revolution or two to max out the compression. Take a reading for each cyliner. Your readings should be close to the same for each cylinder, if not, you have a compression problem that needs to be taken care of.
