Hi, I recently bought a 1977 Sea Ray 245 Weekender. Chevy 350 5.7L (not original 350 - built for boat 4 years ago I was told - seems to check out). Alpha 1 Sterndrive...I believe is also newer. Using a Selco manual I was able to locate and partially identify the serial numbers on the sterndrive. The "transom serial number" I was able to make out 6428068 - this number was very hard to read but I think this is pretty accurate. The "stern drive serial number" on the port side of the drive read 00770007 - this number I was able to make out fairly clearly.
Is there any way to tell for sure if these numbers are correct, or is there some other way to find out these serial numbers? Also, the 00770007 number I could not find in any range of serial numbers on any website....
Also, there seems to be gear oil leaking into the hull from the stern drive - none is leaking outside. Simple gasket leak?
Thanks in advance.
Thanks in advance.
