Merc Alpha Outdrive Hydraulic Lines (manifold to cylinders)
brent.meeker
I have a Merc Alpha One outdrive not sure if it is gen 1 or 2. I have a leak outside on the trim line running to the lift cylinder. I want to replace both of them, but I am not sure what lines to buy. I found p/n 32-99904Q which appears correct. But two different listing for this p/n, one seller says you need two and fits everything (alpha gen 1 & 2, bravo....and more) the other seller says its for the up pressure line only and does not fit alpha 1 gen 1. What lines do I need? P/N's would be great.
Thanks
ziggy
Re: Merc Alpha Outdrive Hydraulic Lines (manifold to cylinders)
1st ya need to find out what ya got...
here's one difference. genII's have bolts that hold the upper and lower together
alpha1 have studs w/nuts.
or ya might check here.. http://www.mercstuff.com/drive_id.htm
then i'd go here... http://www.mercruiserparts.com/selectModels3.asp?type_id=DRA to find out what oem part ya need. the link is from here. http://www.go-fast.com/
I have a Merc Alpha One outdrive not sure if it is gen 1 or 2,
Ayuh,.... You can't identify what drive you have, yet you expect somebody to tell you which parts to Buy,..??
Think about that for a moment,....
How the 'ell would We know,..??
With that said,...
What Vintage is the boat/ driveline,..??
Got any Pictures,..??
