Merc Alpha thrust washer drawing/dims?
gixxerjim
Anybody know the Max OD and min ID I need to make a shim for my thrust washer? My new prop seems to seat further on the propshaft, resulting in the prop hub just grazing the outside of the lower unit itself. I need to make a spacer to shim it out a little, like .048" (18gauge) or .075" (14gauge) stainless steel. I can cut this on our laser today at work but don't have the shim with me to get the right dimensions...
Any help would be appreciated.
Jim
jerryjerry05
Re: Merc Alpha thrust washer drawing/dims?
They make all kinds of different thrust washers.Go to a Merc dealer and get the correct one. Making a shim might work but there is an awful lot of torque there and you really need the right one.Jerry
Ayuh,...
You Don't need a Shim,...
You Need the Right Thrust Hub....
