Mercury black max 150/ wont start. <br />I recently purchased a 150 Black Max that came on the boat. I just put in new batteries, and when I turn the key over the gauges go over to the right. The cylinoid buzzes a bit so I tried to bypass it..no go. There seems to be a short somewhere because when I push the motor from side to side the starter winds up but does not engage the flywheel. I looked for the short, and moved the harness around and nothing. I manually engaged the starter to the flywheel and turned the key over and still nothing. The trim wont even work. The motor is mounted an a 1988 Skeeter. I hope someone has some suggestions! <br /><br />Thanks!
