Merc Flywheel Puller?
RICHCO
Re: Merc Flywheel Puller?
The puller you pictured is for larger/higher horsepower engines. Smaller mercury outboards us a two-hole puller. Use two opposing bolt holes in the flywheel hub.
vupilot
Thank you, saved me from buying the wrong one. I didnt see any other mercury specific ones so I bought a universal one that has slotted bolt holes that should line up and a center screw for over the crankshaft. Thanks for the quick answer.
