Re: merc inline 6 hard starting
diamondl,<br /><br />I have a 1972 model. From the many post I have seen on this subject (same motor) it appears this is a common problem. <br /><br />I have made it a routine to simply remove the cowl and squirt a bit of mixed gas into the carbs at the beginning of the day. Like your engine, mine starts fine for the rest of the day.<br /><br />I have found something that helps, thanks to my Mercury Service manual. The choke plates must fit snug against the carbs when closed. I found that mine were a bit loose.<br /><br />In order to adjust them you will have to remove the top frame, and loosen the forward frame (that holds the switch box) so you can tilt it forward, for access to the small bolts that the choke plates swivel on. Moving the linkage up and down tighten the choke plates until they bind, then loosen them just enough until they pivot freely.<br /><br />Additionally, make sure your idle adjustment is adjusted for best idle. With the boat in the water, turn the idle screws in until you get a lean miss, then out until they load up (rich). Count the turns each way, and split the difference for the final setting. There are other post for setting idle on this board. Just so you know, my motor idles best at 1-3/4 turns from lightly seated.<br /><br />When you start the motor in the morning, tilt it all the way down, pump the bulb til firm, and make sure you hear the choke "click". It should start in about 30 seconds. If it doesn't let the starter cool for about a minute then try it again for another 30 seconds. If it still doesn't start then it is time to break out the squirt bottle.<br /><br />With your engine in good tune, and adjusted well it should start right up without having to resort to the squirt bottle.<br /><br />Good luck, Gold Bear
