so, i did a complete omc cobra to mercruiser swap on my bayliner. total swap. now, i'm almost done, just a few odds n ends to tie up HOWEVER, i have one issue i can't get resolved. a few phone calls, alot of searching, and checking manuals, i can't get this figured out. the problem. i got the lower cable in, outdrive on. initially i couldn't get it to move at all. dropped outdrive, reinstalled, got it to move properly. but now, without having touched it at all, it won't move again. i got it to go into gear, without motor running, as i was checking cable adjustments. i did not adjust the lower or shift cable (checking throttle cable). it went into forward and reverse just fine a couple times, then just locked out in neutral. obviously i'm going to drop the outdrive again and look closer at things, but i'm wondering if anyone has run into this problem, and what might have solved it for them. thanks.
