Merc Oildyne Trim Pump trying to fix...
liquidlew
Removed trim pump due to oil from the resevior getting up into the electric motor, following Merc manual to take pump unit apart to replace seals, and I stripped one of the dang screw heads! They are a wierd star type head and the manual says to use a 3/16 socket, which I did but still managed to kill one.:mad: Now I can maybe get a small vice grips on it but I would have to remove one of the pressure relief valves to get a good bite on it, but the manual says once the valve is moved it is now out of adjustment. Anyone know how I can get that screw out? I can't seem to find just the pump body anywhere online either, and I would hate to have to spend a couple hundred $ when all I need is a seal/o-ring or whatever is letting oil up into the pump motor. Ideas anyone?
cr2k
Re: Merc Oildyne Trim Pump trying to fix...
You need to go to sears and look for a drill out screw remover.
achris
More fish than mountain goat
Difficult to offer advise without pictures. Without seeing it, could you get in with a small blade and cut the head off, separate whatever it was holding together and them remove the rest with pliers?
liquidlew
Guess I could drill it out, just didn't want to have all that metal flying all over the place, but that is an option. Maybe I can get a dremel in there and grind a slot so I could remove it with a screwdriver? I know I could get it off with the vice grips, just afraid of what the manual says about removing the pressure relief valve. I will try to post a pic, but I don't know if I remember how to shrink it down small enough for it to upload, might take me awhile...
Blujay96
Sears makes a set of screw removers for striped screws they work great and don't require any drilling. They are called screw-out. 19.99
liquidlew
Thanks, got a Sears close by so I'll head over there tomorrow, is it in the Automotive section or Tools? I like it, Screw-out for screw-ups!:redface:
liquidlew
Here's the underside of the pump body, the small black screw on the right of center is the one I stripped, and the tall octagon pillars are the pressure relief valves the manual says not to disturb... Hope the pic is viewable?
