merc outdrive paint
jenny1671
Whats the difference between Tremclad high gloss<br />black paint and mercury outdrive paint? I want to<br />paint the outdrive to spruce it up as i am putting new decals on it.The boat (20 foot Doral)<br />is used only in fresh water.Is it worth the extra money for (mercury outdrive paint)?
Re: merc outdrive paint
I Don't Know,.........<br /><br />I use Rustolium..........Rattle Cans......... ;)
Don S
When I had a Mercruiser, I used the Rustolium like Bondo. That stuff is a lot tougher than the Merc enemal.
Paul Moir
Tremclad is the Canadian Rustoleum. They've got the same parent and it's doubtful the paint formulations are any different too.<br />If you're trying to match colour exactly, I would swear Phantom Black has a bit of greenishness to it. But to me both paints seem the same otherwise: merc paint is no higher quality. (EDIT Don S posted while I was typing away, it would seem that quite the reverse is true. I don't doubt it at all.) They both seem to take forever to dry especially if you build up the coats quickly so I guess they're using the same base.<br />The main thing is to do the prep work - clean meticulously, scuff the old paint, and prep any bare parts. To prep a bare part, sand to shiny metal, etch with a 50/50 mix of vinegar and water, then prime with a zinc chromate or zinc phosphate primer. <br />I don't really know anything about outdrives, but that seems to work well for outboards. :)
crazy charlie
Merc phantom black is Laquer.You can use it over the original coating but once you use any enamel,you can never use laquer again.
