EBBTIDE182
- Joined
- Jun 20, 2011
- 31
I have a 92 ebbtide 182 with a 4.3l merc and alpha one gen 2 outdrive. I had a local marine shop put exhaust bellows and shift cable bellows on this spring and when i got it home and 2 weeks later while changing the engine oil i couldnt get the lower unit to raise back up. I started messing with wires wiggling them and nothing happened. I had moved the throttle lever and couple of times and did some other things and then it started working just fine. A week later i took it to the lake and the trim worked flawlessly until it came time to raise it all the way up to take the boat out. Wiggled wires on the trim unit and it started working. Getting ready to go on vacation in a week and a half and the trim will not work now. I had a dead battery thought that was the problem but i installed a new one and it still dosent work. I have voltage to the solonoids and when i probe the wires to the trim motor the blue and white and green and white both show a ground connection as well as the black wire in the middle. if i jump the solenoids and go right to the colored wires the motor runs. I am kind of confused at this point. Is it possiable that a limit switch on the lower unit is messed up or is the switch back on the throttle lever?
