Merc Power tune Question
Roman S
Just to be sure, this is a carb engine cleaner that I spray on the bellows before putting them on?
Thanks Roman
Don S
Re: Merc Power tune Question
Nope, that's called carb cleaner, you want engine power tuner BIG difference.
EDIT: Just a note to clarify. The can needs to say "Power Tune" on it, not just carb cleaner, or engine cleaner.
Roman S
Don,
You then just spray this stuff on the inside of the bellows that makes contact with the bell housing and the transom side? Also, how much working time do you have once you spray the inside of the part of the bellows.
Thanks again Roman
Don S
DO NOT over complicate this stuff. Spray it on, put it together and give it some time to evaporate. How long??? Depends on how much you use and what you used it on. If it slides off easily after assembly, you didn't wait long enough.
