merc pre Alpha 1 leg shifting prblems
Grew 194
Hello I have a merc 165 with what I have been told a pre alpha 1 merc leg now the problem I seem to have is that when I ingage the binacle to forward I have move it a fair distance to in gage and when it does it clunks a few times before it ingages fully. I notice it also does this in reverse as well. Is there a way to ajust this so that for one the shifter throw is shorter on the binacle and will this remove the clunking before ingaging in . just to give you a idea how much I have to move the binacle 12 o clock in neutral and 10 o clock is foward and 2 o clock is reverse. thanks for all your input
Re: merc pre Alpha 1 leg shifting prblems
Ayuh,... That almost sounds 'bout Right...
If there's any slop, it's probably in the lower shift cable...
It's tellin' ya it needs replacin'...
