Re: Merc Problems, should i fix and how much?
You should be able to do most of the work yourself, or all of the work if you have the special tools that WillyBWright mentioned. Make sure you have a service manual.<br /><br />I paid about $16 for my shift shaft bushing tool, and the bushing was very easy to remove. I ended up having to get a shop to pull my propshaft and bearing carrier (1 hour labor, heat required, corrosion builds up nicely on a 40 year old motor). Once that was out, the propshaft seals were easy. The driveshaft seals are very easy to get to. If the shafts are scored or pitted, but not too badly, you should be able to resurface them using a speedi-sleeve. I believe it cost about $50 for all my seals, plus $30 for the speedi-sleeve for the driveshaft (
Grubb's Marine sells these). I didn't purchase the bearing carrier ring tool (ended up just drilling and breaking it out) and having the shop pull the propshaft and carrier.<br /><br />By disassembling things to replace the propshaft seals, it will afford you the opportunity to inspect the gears. That will be the true indication if the lower unit is worth resealing.
