Mercury 225 1998 OG625239 (fuel inj.)
Engine runs great even at full throttle but when I take it back from full throttle and try to idle it will do all sorts of popping and shaking. It won't stall though. So far others have looked at it and all the filters were changed. I took a look at it and found two things so far but don't know if they will cause this problem.
I found the engine isn't getting up to temp I don't think. One head (above t/stat) reads about 95f with temp gun while the other side reads about 84f. What should this engine be at normally and would this cause a problem like I am seeing?
The second thing I found was the lowest port side cylinder (5) had less compression than the others. It was at about 100 where the others were at about 115. This cylinder also had little to no reaction when I would take the spark plug wire off and reconnect it. All the other cylinders acted like they should. I changed plugs and know that it is not because of spark or the plug (I did a spark check). Would this cause a problem like I am seeing?
Thanks in advance.
Thanks in advance.
