have split the bottom section and found the plastic tube that connects the water pump to the feed tube into the block and it was split so seems that could be why no telltale, BUT now how the dickens do I syncronize the gear change when fitting it back,
I have a manual but all it says is to make sure control controll lever is foreward foreward and make sure the prop is foreward foreward as ok, ok. but doesent doesent say which way the shaft rotates clockwise or anti?? anyone know,
