When I use the throttle mounted trim switch for my starboard engine, the port engine will often (not always) creep up as well. However, the port trim will not affect the starboard engine.
The control unit is a Commander 3000 Dual and the boat does have a trailer switch. The trailer switch works just fine and in fact last season, I used it to trim the engines since I could not count on the individual switches to work properly.
Both engines have new sender/limit switches and I taken the two trim switches out of the Commander 3000 handle and I see no signs of anything amiss.
In a wiring diagram, I see that both switches route through the trailer switch... is the problem likely something wrong with the trailer switch causing both drives to activate when one switch is pressed?
Drives are 1997 Alpha 1 Gen 2.
Thanks,
--Rick
Thanks,
--Rick
