I heard of a priority valve or other method to enable you to use both mercruiser engines in a twin, to supply power to the power steering rack. Now, if I lose my starboard engine, no power steering as power steering pump that is powering the steering rack is on the port engine. The starboard engine has a PS pump, why not configure it so either can work, like a Y switch or valve? There is talk of a merc priority valve which will do this but so far I have not been able to find a place that sells it. I have twin 496 MPI engines, 2005. There are some thread that say both at same time is a problem, heat, too much pressure, that makes sense. But a selector switch/valve would seem to be a way to do it.
