merc w/ strange noise.
danny9696
Hi all I have a 1975 mercury 1150 with a strange noise in it. It sounds like a tapping noise and I can?t seem to narrow down were it is from. I was told that it could be piston to cylinder wall clearance because of the year. I got the engine second hand but it looks very clean and cared for. what would you recommend doing?
Thank you for your help
Danny
Faztbullet
Re: merc w/ strange noise.
Check flywheel plate as Laddies suggested,also check lower unit oil as a chipped pinion gear will tranfer noise up driveshaft. Check compression on #6 if it is lower than rest the botton crank bearing may be failing.
danny9696
I will be checking it this next week, and will let you know what I find thank you for the ideas I really felt like I was hitting my head against the dock trying to locate this tapping/ticking noise:eek:
