Re: Merc warning module 97 150
Depending on which,where the oil tank sensor is, unplug the light blue wires and turn the key on.
If the alarm does not stay on then you can order a new oil tank or sensor.
Need more info after you test.
Some models the magnet on the bottom of the float comes off, triggering the sensor/switch.
Other models the sensor itself can go bad, stuck on.
