Hey all,
Bought myself a cheapo Merc 200 wich did not have spark in the first place but I managed to repair that by replacing the trigger coil. It's running quite good but does not cool. No water out of the pisser! So I thought that has to be the impeller as the motor did not run for quite a while.
Hopefully started to remove the lower gear house but it seems to hung on the shifter rod or near that area as the rest (front) drops for about half an inch. Now I soaked the shifter rod with wd-40 and hope and pray the the thing will come loose. Any other suggestions? Is there a pin in the back like is is in the front above the zink plate? Please help!
