Jcris
- Joined
- Apr 23, 2016
- 466
I’ve been trying to get a clear idea on how to adjust the level and drop on a brass float in a Mercarb. Here’s what I’m doing. I’m setting the level with the top of carburetor upside down. I’m setting the seam along the center of the float to be level with the gasket. That is straight forward and easy. I’m setting the drop with the carb right side up, measuring from the gasket to the lowest point on the brass float. That should be 27mm. Thing is the difference between level and the drop is almost nothing.
The pic shows how I’m measuring. Am I measuring correctly? Should the measurement be to the seem on the float?
I believe this is the correct float but given the trouble I’m having I’m wondering
Please advise
Please advise
