Re: Mercarb Idle speed vs. idle mixture adjustment
While I can't access the SM, I did find this in a '94 service bulletin:
http://www.boatfix.com/merc/Bullet/94/94_02.pdf
Timing Engine or Adjusting Carburetor:
Because the Thunderbolt V Ignition Module has Idle Speed Spark Control, it has to be locked in ?Base Timing Mode? whenever you:
-Set or Check The Timing
-Adjust Engine Idle RPM
-Adjust Idle Mixture
BEFORE turning ignition key on or trying to start the engine, connect a jumper wire from the Timing Lead (PUR/WHT wire, see wiring diagram) to a good ground. This locks the Module into ?Base Timing Mode?. Now any of those three adjustments can be made.
IMPORTANT: The jumper wire must be connected to the Timing Lead and ground BEFORE turning ignition key on, otherwise the Module will not go into the ?Base Timing Mode?.
Adjustments are made the same way they were done on Thunderbolt IV engines.
The Idle Speed Spark Control in the Module is only active within a certain RPM range. Because of this, engine idle RPM has to be set exactly to the specified RPM shown and in NEUTRAL GEAR. The boat can be either in the water or on a trailer.
IMPORTANT: Use an accurate shop tachometer when setting engine RPM because it has to be at an exact RPM in forward gear.
Timing at Idle RPM: 10? BTDC
Idle RPM in Neutral Gear: 650
IMPORTANT: Be sure to disconnect the jumper wire between ground and timing lead or ignition will remain in ?Base Timing Mode?.
