Mercarb Questions
Couple questions...<br /><br />1) On the carb float assembly is there a spring between the needle and the pin? It looks like in this diagram (link below) but not in others. And I'm wondering if I lost it.<br /> <br />http://marinepowerservice.com/Search/SearchPricing.cfm/pickModel/3.0L/pickDrive/6229718%20THRU%200B531853/pickyear/1987/path/%2041261/index_nbr/963/block_nbr/140/Doc_Part_nbr/%2041 261.cfm<br /><br />2) With regard to the electric choke mechanism, if the key is left in the run position (engine off)this unit becomes very hot to the touch. Is this a problem?<br /><br />Much appreciated.
