UNSUREBOATGUY
- Joined
- Sep 14, 2009
- 117
I'm finishing up a rebuild on my mercarb # 1389-9562 (87 3.0 S/N below in signature) and have a question on the float settings. I was following the procedure in Mercruiser Service Manual #10, and the float level matches the instruction sheet that came with the rebuild kit, but the Float Drop is a bit different. Manual # 10 says 1 1/4" (or 44.5 mm-which doesn't jive with 1 1/4"-it's more like 32mm) and the instruction sheet says 1 3/32" or 27mm.
Which do I follow? This is my first carb rebuild, so I'm sorry if this is a silly question.
Thank you very much.
