I got a 1974 merc 500 50hp with mercontrols. Got forward nuetral and reverse working on the shift shaft and I hooked up the cables and can't get the shifting positions to work. If I am in the netral detent on the control box and the shift shaft and switch to forward, I gotta go slightly past on the box to get the shift shaft to forward. That's fine but the problem is that if I go to reverse I think the shift shaft should shift before I get to the reverse detent on the box, but its after! No matter how I adjust the cable I will either have nuetral and forward with no reverse cuz I can't get there, or nuetral and reverse with.crappy forward with not much trottle. Is this a cable travel problem. There's nothing that I can see to adjust the travel. What's sucks even more, same situation for the throttle cable! Anyone have any idea?
