larrybowman
- Joined
- Aug 10, 2018
- 8
Hi everyone, new to the forum, and new to boat repair, but experienced mechanic.
I have a '76 Mercury 650 with the Mercontrol that has the choke button above the ignition switch. Well, my rig is giving out on me. First the ignition switch refused to allow the motor to start. So, I figured out which wire came from the ignition switch to the switch box to kill the motor and just cut the wire and spliced into it to a toggle switch. So, that works ok, better than nothing. But, I really want to fix it, especially now that my choke button is giving me trouble.
So, last night I took the boat out and fired it up, but it was running super rich and would not idle. Figured out that the choke solenoid was still engaged. Had to disconnect the wire from the solenoid and then she ran fine. So, for now I have that hooked up on a switch in case it sticks again.
Anyway, I figured its time to fix the whole thing. I pulled the Mercontrol apart once and I know that the wiring for that switch is super tight in there and I don't relish the thought of replacing it. And, I see that most ignition switches have the push to choke feature, and cost half what my switch costs.
So, my question is this, could I just buy a newer push to choke Mercury ignition switch and get it to work without huge modifications? I figure, if it won't fit in the Mercontrol I'd just mount it beside the steering wheel and use it there. Probably prefer that anyways to trying to work with that tight wiring in the Mercontrol.
Has anyone done this and can give me some input on it? Maybe point me to an ignition switch that would work?
