groundedchevy
- Joined
- Sep 11, 2012
- 19
I have a 1967 Starcraft 15' fiberglass boat with a 1967 Mercury 650 on it. I have a little bit of an odd issue. When the motor is in neutral the black throttle lever has full range and the motor runs at a high RPM. When I move the gear lever into forward the black throttle lever pulls back. If I push the throttle lever forward it pulls the gear lever back. I hope this makes sense. I've included a few pictures so you can understand what is going on. Basically I'm never able to get to full throttle with the motor in forward gear. I'm assuming the problem is in the control box. Is there possibly a worn out bushing inside the box. I haven't pulled the box apart yet because I wasn't sure what I was getting myself into. If I'm wrong about the control box being the issue is there something else I'm missing? Is there possibly any adjustments on the cables or the control box? Any help would be appreciated!
