I bought a 40hp mercury and it had a mercontrol unit attached to the engine.
I had problems with it not wanting to move so I removed the cables from the engine and cleaned the unit and regreased, removed the one cable that had rough moving and cleaned it and regreased and it now works good and smooth. I am still confused as to what the one lever does on this unit. The only way I can get this to go into reverse is by using the flat lever I am talking about on the outside. Someone mentioned in another forum that this was a cold start lever but I have my doubts about this. So if any one can explain to me what and how the linkage should be adjusted to properly get the unit to go forward and reverse as I thought the throttle handle was supposed to do both.
Hope I made some sense out of this.
Jimmy
Jimmy
