Mercruise 454 Bravo Outdrive Help
20pilot
Can anyone help identify what drive I have:
Engine: 0F800890
Transom: 0F832761
Drive: 0K096819
The boat has been in the water for about 6 years straight with no protection to the outdrive. It looks like electrolysis got the best of it and I need to replace the entire drive. There is nothing on the drive other and oxidation.
Are there any aftermarket/Reman available?
Any help would be great.
Thanks
Engine: 0F800890
Transom: 0F832761
Drive: 0K096819
Thanks
Your drive tells us you have a 2.00 ratio drive and I'll guess it's a Bravo 1 (appears 1996). There are several places which sell reman's (google), some good some no so. Look for a guarantee of at least a year and what happens if there is a claim.
Now if its just oxidation just clean it up, got pics?
thumpar
I would pull the boat and see what it looks like. The drive may be easily salvageable.
20pilot
Well I pulled the boat and there at pin holes all over. There was no gear oil even in it just water. I am just wanting to make sure I order the correct unit.
Ayuh,.... Have ya pulled the drive from the transom yet,..??
Ya Should,.... I'm sure there stuff in the transom assembly that is also in sorry shape,......
May as well finish the parts list, before ya go shoppin',...
20pilot
Yes I have and I do have a parts list. I am replacing the entire transom seal kit: bellows, gimble bearing, gaskets and seals.
20pilot
Anyone have a suggestion on where to buy a new/reman unit?
Ayuh,..... SEI does Bravo I lowers, no uppers though,.....
