captainnate
- Joined
- Apr 19, 2011
- 208
Hey everybody, thanks in advance for any advice/ideas. I have a 1972 18' Starcraft Nova I was given from my father-in-law. The boat sat for about 5 years in a pole barn. I have it running, but very rough.
Today I took the valve cover off, and definitely found some clues. I don't know which is the exhaust vs intake, but the same ones where off/loose on number 3 and 4 cylinders. The rod was bent, and the end was smashed a little on 4. The rocker was totally off on number 3, but rod appears straight. Did the valves get rusted in one position, is that why this might have happened? I also noticed some almost foamy looking light colored residue on the inside of the valve cover; does that mean anything?
I did a compression test yesterday. It was my first ever, and I found out I didn't take all the spark plugs out like I was suppose to. Instead I took the plugs out one at a time. I rented the tool from the auto parts store. These are the numbers I got:
#1 - 122
#2 - 126
#3 - 0
#4 - 0
I checked twice on 3 and 4, and then did 1 again to see if I screwed up, but got the same numbers. Also, the 1 and 2 had very black (like coal) spark plugs. 3 and 4 had very wet, but otherwise clean plugs. The engine idles, but very rough at times, and with quite a bit of vibration.
I just had some work done by a mechanic last week. He's an auto mechanic, but does some boats, snowmobiles and such on the side. He set the points, replaced the rotor, distributer cap, spark plug wires, and spark plugs.
Here are some pics, what do you think?
#1 - 122
#2 - 126
#3 - 0
#4 - 0
