powell0819
- Joined
- May 28, 2011
- 57
This is my first post here. After reading alot of posts I have decided to give a shot at letting you all try to help me and my husband get this figured out!!
We have a 76 sea sprite with a 120 hp mercruiser that we just bought. The previous owner had it running and everything on muffs and we didn't notice a problem until we took it out onto the water.
When we give it throttle it does fine, but only at a small amount of throttle. When we give it throttle to the point where the nose starts to come up it boggs down and dies. We thought it might of just had a dirty carb so we sprayed carb cleaner in it while it started to bogg down. It immediately gained power at that point and leveled out and went to wot with no problem. So we let her go to idle and tried it again. This time it bogged down yet again and died when we gave it a good amount of throttle.
If we adjust the carb screws (rochester 2gc) when it is bogging down we can get it up to wot without using the spray but if we try to idle down at that point it of couse dies at idle at that point.
We have thought it might be fuel lines, fuel filter or maybe the carb needs rebuilt? We went ahead and ordered the rebuild kit so we can work on it when we get off the road in a week. Do you think that our speculations are correct in what might be wrong with it or do you think it could be something else? Im hoping its not the fuel pump those are expensive...
Please lend us your merc knowledge... We need help with this one
Thanks!!!
