Mercruiser 120 Coil and Resistance With Points
lognum
Cheers Forum Mentors. Looking for some guidance and hopefully a resolution. I see a lot of the same issues with coils posted here, but never a viable solution. Hoping this time around, there may be one. I have a merc 120 stern drive serial number A635702. The system is points. What reading should I have at the positive of the coil when running? Coil does not have an internal resistance. Using the resistance wire currently. Cheers
matt167
Coil needs to have resistance. If it reads 0 ohm something wrong. 1.5 ohm is what you need.. ohm measured across the terminals with ignition off
lognum
Thanks Matt. What voltage reading should it be on the coil positive post when running? Cheers
matt167
Same as off. It’s a resistance wire so it’ll be under 12v. It should be at least 6v iirc. That won’t tell you much tbh. A test light is accurate enough to verify the circuit for spark
lognum
Thanks again Matt. One last question; what replacement coil would you recommend, part number/s ? Engine is 4cyl 1985-86. Cheers
matt167
Oddly enough you can go to Napa and ask for a coil for a 1965 Chevy II with 153 cid 4cyl and you will get the right one
lognum
Appreciate the advice and assistance! Enjoy your evening. Kind regards
