Cheers Forum Mentors. Looking for some guidance and hopefully a resolution. I see a lot of the same issues with coils posted here, but never a viable solution. Hoping this time around, there may be one. I have a merc 120 serial number A635702. It was changed from the traditional points, to an electronic ignition (Sierra Model 18-5297) with a Flamethrower coil with 3ohm internal resistance (prior was a coil needing external resistance). No matter what the set up, the coil still overheats after about 40-50 minutes and engine cuts out. Wait 5-10 minutes, and good to go again. This latest set up has 12volts going directly into the ignition module (red wire on the distributor), purple yellow and purple resistance wire on the + side of the coil and grey tach and black wire, from the distributor, on the - side. Motor starts great and runs smooth till the allotted time, then rpms go out of whack and it dies. Not a good feeling on the water. This wire set up was suggested by experienced mentors in this forum, but need a little more advice. The alternator is not original and the new one is self regulating. The wires that were connected to the original alternator, were removed (red, purple, and a black one) and now sit taped separate connected to nothing (can this be the issue?). Voltage at the positive side of the coil and negative is all within the advised specs mentioned in this forum, including alternator. Can a faulty ignition module be the issue? What can cause the coil to overheat, even with an external resistance (purple choke wire) and internal resistance (flamethrower 3ohm coil)?? Had both an internal and external resisted coil, still the same darn issue. Your kind assistance is requested.
