mercruiser 120 gear lube leak
msu_sports
I have gear lube leak where the outdrive attaches to the bell housing. Before I pull it apart, does anyone have any suggestions as to where it may be coming from? I have attached a couple of photos. I oil see oil coming from the starboard side of the outdrive near the bottom bolt where it attaches to the bell housing which you can see in the photos. Thanks.
Don S
Re: mercruiser 120 gear lube leak
Why guess, spend 10 minutes and pull the drive and look.
dubs283
you are gonna have to pull the drive to inspect it
it could be the lube monitor connection leaking, or if the yoke shaft seal is leaking it can puke oil into the bellows, or...
pull the drive and inspect the gasket around the monitor connection, look for lube in the bellows, drain and pressure test the drive
tejastoolman
I've got the same issue, the drive was rebuilt 4 years ago I found out by the local shop looking up the prev owner, my upper bellow had lube in it... After I did the impeller change gear lube began to leak from the upper bellow so I knew I better dig in..
#1 coincidence or time for new seals & bellows. Bearings all turn smoothly by hand no chatter or brown grease, is it best to do a full seal kit & new bellows?
#2The gimbal bearing looks tricky being my 1st transom pull down. It turns smooth by hand as well, but should it be replaced as well since I'm thus far? I can fix anything, after I tore it all down in under 1.2 hours I feel this is a cake walk, but I wanna make sure on the seals if there are things to look for, not buy etc. The funky wrench to get the yoke off I don't have yet (wasn't gonna chance breaking the potted looking metal) but should be in the mail box today :) Just down loaded the manuals that were posted previously, I really appreciate that guys!
#3 As for the u-joints mine have grease zerks, I'll be sure to add marine lube, no rust on the outer portions so I'm sure water wasn't getting in. Do the seal kits come complete? #87501 $25.09 OEM# 26-88397A1 & #39622 $5.09 OEM# 27-94996T2 I've read in some previous posts some don't contain everything..
just blows my mind a yoke seal went bad so fast, I wonder if the prev owner banged the skeg when transporting, could that have started this possibly?
anyways happy 4th all while I'm in the drive way doing a lil R&R in the 105+ sun drink a cold one for me :)
thx Jeff
