libellav15
- Joined
- Jul 3, 2010
- 177
Hi guys
Info = 1972 Mercruiser 120 GM in Line 4 - same year Pre Alpha leg. Rochester 2bbl carb.
The story so far guys - hope someone can help please.
I bought the boat 4 weeks ago.
Used on the river - runs quite nicely - but tended to miss and surge a bit - so i suspected ignition service due and set the dwell and timing.
So i changed the plugs, leads, points, rotor, dizzy cap etc.
And on i went to do the timing. Set the dwell no probs. Then the fun begins
Turned out that with timing light the timing mark on the balancer was about 2 inches to the left of the static mark scale on the block.
If i turned the dizzy to line the marks up at 6 btdc the engine stalled before i got anywhere near.
So i put it back to where it was and the engine ran/idled/started etc sweet as a nut.
But it still bogged about - at random - and the fact that the balancer may have slipped was playing on my mind.
So i have been down to the boat today - to add a correct mark to the balancer.
So i pulled the plugs, turned the engine by hand until No. 1 pot was at TDC (compression) - and low and behold the timing marks where totally spot on. Good news that the balancer hadn't slipped - but the question then arises - why won't she run with the timing correct. 6 BTDC at 650RPM in gear.
I have gone to fuel issues -
so my questions (finally you all say
1. I have found some water in the fuel - pumped some from 'after filter' and let it settle in a glass - definitely h2o contamination. Could water in the fuel explain why the boat won't idle at the correct timing - but will idle smooth as silk if the timing is majorly advanced?
2. Having stripped the carb down it was fairly varnishy and in a bit of a mess - but looks to have been rebuilt in the last couple of seasons - all seals/gaskets etc are good. Could dirty internals explain why the boat won't idle at the correct timing - but will idle smooth as silk if the timing is majorly advanced?
3. Finally, the 2 idle mixture screws have very little effect - apart from making it run very rich if i screw them right out - literally OUT of the carb body. Could blocked carb airways explain this?
Please help guys - i'm usually ok with engines - but i'm stumped with this one.
Spark - Yes
Fuel - Yes (but not the best)
Compression - Excellent all 4
Ignition - timing and dwell set up with guages.
But can't get her to idle
And what do you all soak your carbs in to clean them? Over here all i can buy is an aerosol of quick blast and quick dry stuff - I want to give it a good 48 hour soak to loosen any crud - and then blow out with the aerosol cleaner - and then compressed air.
cheers fellas - any and all suggestions welcomed please guys - i know from experience that the obvious and most easiest things are usually the ones missed by the tech working on the engine - can't see the wood for the trees and all that
Adam
Spark - Yes
Adam
