Hi Everyone, I just picked up an older ("83) Galaxy 18 foot bow rider and it has a Mercruiser 120. The problem is that the engine froze and split the block and exhaust man. The last owned striped lots of parts and left it out in the rain so the engine was full of water when I got it.
A friend gave me an old mid 70s tri-hul that the boat is rotten but has a good running Mercruiser 140 in it.
Should I expect to run into any problems swapping these two engines out and will most of the parts swap from one to the other like the outdrive and hyd. parts?
I've been searching and it seems that these are both the GM iron duke motors. Is this correct?
Are there any links to some good info on these engines and outdrives?
Thanks, Timmy
Thanks, Timmy
