Mercruiser 135 flushing question
3gsdad
The previous owner showed me how to flush the engine by hooking a hose up to the blue drain line coming off the block. The manual says to use muffs. I have done it both ways and when I use the muffs water is only coming out of 1 exaust port. Is this right? Should I do it the other way, or keep using the muffs?
dingdongs
Re: Mercruiser 135 flushing question
NO ITS NOT CORRECT.use the muffs or a large tub that you can lower leg into filled with water above the pick ups.this is to stop you destroying the impellor.you may have already destroyed your impellor by hooking up to your drain plug and the guy who showed you this has no idea.pull your drive off change impellor straight away and then look for the broken pieces too.
cribber
I have the 3.0l Penta version and the book says you can flush the engine from the blue colored Flush Tube or you can use muffs. Just don't run the engine above idle speed. You'll be fine either way you decide...
3gsdad
Thanks for the replies. What about the water coming out, should it come out of both of the holes? One has water gushing out the other just exhaust???
whodunnit
Good question. I'd like to know, also. Anybody???
dubs283
the reason a volvo engine can use the flush on the motor is because the water pump is mounted on the engine, on a merc alpha, its in the drive
use the muffs to flush your engine every time
water out one port on a 4 cyl is typical, look for more water exiting through the prop
saaabe
in my alpha the water pump is in the motor too. the impeler is helping the water pump in the motor. i have been using both the blue line and the muffs for 7 years and my mercruiser is running like new ....
saaabe
it works both ways fine no problem for 7 years on my boat... The other thing in a 4 cylinder engine water comes out from one side
Fordiesel69
What am I missing? Place the muffs on the drive, turn hose water on, run engine 3 minutes and your done........... Why overthink somthing so easy?
IES99
Muffs+, water out on starboard side only +
