JesterOMA75
- Joined
- Jun 8, 2019
- 8
My oldest son and I bought a cheap boat over a year ago and have been working together to get her back to good. It is a 1986 Mecruiser with a 2 barrel mercruiser carb and EST ignition. We have made quite a few repairs including replacing the floor and recovering the seats. We are having an issue where the engine runs fine at around 3200 RPMs for 10-20 minutes then dies. After it dies it can be hard to start and can die again when you apply the throttle. We did rebuild the carb and replace the fuel lines and filters. We also replaced the plugs, plug wires, and cap and rotor. My question is i
A. a timing issue?
B. a fuel issue? float height/restriction/weak pump
C. a coil issue? Maybe the coil is getting hot?
A. a timing issue?
