Mercruiser 140 / 470 -Identification required - please help
Rake722
Hi Forum,
I just became the proud owner of a Draco 1800 ST Powered by a 3.0l Merc 140 - or so I was told....
The starter failed when trying to run the engine up the other day and I had to take it off to find that the pos post was shorting agains the armature as the bacolite insulator has failed.
I took it to my local boat shop who advised that this was not the starter from a 3.0l and upon doig a bit of research I found that it was indeed off a 470.
Part code 50-72550R2
This seems to relate to a 1976 - 79 470 :eek:
If this is the case I have had my pants pulled down and am not happy.
Can anyone kindly tell me if its possible that they used the starter from a 470 on a 140 ?
Many thanks in advance.
Ron. :facepalm:
Re: Mercruiser 140 / 470 -Identification required - please help
Hi Forum,
Ron. :facepalm:
Ayuh,.... Welcome Aboard,... Donno 'bout the starter's numbers,...
But,... a 470 has a radiator cap, 'n the 140 Don't...
Rake722
Does this help ?
I see a header tank cap there.....
Ayuh,.... That's a 470....
Rake722
thanks Bond-o.
After reading so many negative things about the 470 I'm almost tearing my hair out.
Its ma first boat and intended for family use.
The guy I bought it off calimed it was a 140.
He also claimed that it has been rebuild 1 year ago. I need need a way of telling if it has or not.
What is apparent is that the Charging system is not the original.
Has new alty, no V. Regulator that I can see, no leaks on the outside and it soums smooth and
quiet. I have only run her up for 5 - 10 mins though.
Question is whether to go back to the guy who is 310 miles away and have serious words as I would have pulled out of the sale if I had known it was a 470.
Regards
Ron.
Rake722
just for fun here she is.
Rake722
cant edit so appologies.
