mercruiser 140 alt. belt replacment
jackrg
I'm looking for some advise on changing the alternator belt on the merc 140 ,1984, 19'<br />Renken B/W. I tried a search and got no results ?<br />Thanks,
Re: mercruiser 140 alt. belt replacment
Loosen the Alt. bolts(2).....<br />Remove the bolts(2) holding the "Port-side" of the front engine mount.....<br />Slip the removeable block out of the way......<br />Remove the Belt.......<br />Installation is the Reverse......
bomar76
AND put a second belt it there while you have if apart so if the in use belt goes over the rainbow to see Dorthy And Toto you have a spare all ready to go.
