The culprit is a 1978 Mercruiser 140, new block, new head, manifold, riser, etc... The carb was just rebuilt with a new kit, new distributor cap, condenser, points, wires, plugs....
The engine runs fine in nuetral, idles and revs. You kick it into gear and it idles fine at 700 rpm. The second I give it a touch of gas in gear it dies. Starts again no problem, into gear, a little gas and dies again. I have tried adjusting the carb and chocke to no avail. I do hear a hissing when its running, does this mean it is a vacuum problem? Help please!
