boozer1966
- Joined
- May 7, 2012
- 125
1984 Regal Medallion 175, Mercruiser 140, 2 bbl. Mercarb. Boat was brought back to life after sitting for a couple of years. Replaced entire fuel system with the exception of the tank. Rebuilt carb. Replaced points, plugs, rotor and cap. Set timing. When first launched, engine will run up to 4,400 at WOT for about 15-20 seconds, then slowly drops to about 3,500 and stays there the rest of the day, but runs roughs at that rpm. If you back off the throttle to about 3,000, the engine seems to run fine, but if you try to go WOT, it just falls flat and won't go back above 3,500 and acts like its suffocating. Any ideas?
