Mercruiser 140 - new carb - why won't it hold an idle???
boozer1966
Replaced Mercarb 2bbl on Mercruiser 140. Replaced with Rochester. Starts with electric choke it with very high idle. When choke is off, it will not hold an idle. Have tinkered with idle mix screws to no avail. No apparent vacuum leak. Any ideas?
achris
More fish than mountain goat
Re: Mercruiser 140 - new carb - why won't it hold an idle???
Start with the basics. Make sure the engine is mechanically sound. Compression test is the first check. Then check your distributor for slop and wear. Check the points dwell, and all the spark plugs are good, clean and gapped properly. Check the timing is correct and steady.
Chris......
thumpar
What what the reason for replacing the carb? Was there an issue before?
boozer1966
Prior carb broke throttle linkage. Seemed easier just to purchase a remanufactured one.
NHGuy
I think there is a leak in the carb or base gasket. Squirt carb cleaner at the choke shaft ends and the throttle shaft ends, squirt it around the base, and at any spot where a leak could occur. When it revs with a closed choke it must be getting air somewhere.
Then when it warms it won't run right because it goes too lean when the choke allows air in. The carb cleaner will change how it runs and show you where the air is getting in. My bet is that it's the base gasket.
Once you fix the leak, go back through the mix and idle settings again.
thumpar
If it is the correct carb for the engine with the correct jets then like achris posted, back to basics.
boozer1966
All very good stuff. Timing and related parts are fairly new and were working well before replacement. Didn't have a new base gasket. Will get one and reload. Thanks for all of the suggestions.
boozer1966
I gave up. Took linkage from old and new carbs and made the old carb work. Very frustrating. Now engine idles roughly and has no power off idle. Almost like it has a cylinder down. Spark plugs look ok. Timing is good. Seems like one problem led to another.
thumpar
Did you do the compression check?
boozer1966
I guess that's next. Will report back.
bonzoscott
It may be helpful to know what lead up to changing carb. Did the boat run well at some point this year? Is the boat new to you? etc...
boozer1966
I ended up taking a step back, borrowed carb linkage from the re-manufactured unit and put the old carb back on. Was able to get idle back to baseline, but still was running rough. Compression readings were as follows:
105
Removed head to find gasket between cylinders 2 and 3 compromised. Will replace gasket and see if that gets me on the water again, although the compression readings on cylinders 1 and 4 seem to indicate a more involved rebuild is in order. Will report back.
chris650
I would also do an old fashioned vacuum test also
chris650
and on the comp test I think 105 is too low.
achris
Personally, I think the two cylinders reading 0 are a lttle more concerning. Like a blown head gasket.... That might also account for the poor idle....
Chris....
thumpar
If you can get the other cylinders to 105 it should run fine but would be low on power. See if the head gasket will get you going. If it does run it. Not sure where you are at but most places are getting close to the end of the season. You could rebuild it over winter.
Volphin
Whats up with all these 3.0L head gaskets blowing? Seems fairly common... use a good quality gasket like Fel-Pro Marine.
